4" ReadyLift with stock wheels/tires.
I can't recommend it though....CV angles are too great resulting in noise and vibration.  Mine started immediately after install and is getting worse.  ReadyLift says they are within "safe tolerance" but I cannot ignore the noise and rumbling it's doing.  I'm taking it off this weekend and ReadyLift is giving me my money back.  I'm just putting a set of 2" level struts on it and calling it a day.
I think this is a more widespread problem than they think because most folks just chalk it up to tire noise.  I'm on stock Bridgestones so I hear and feel every little thing the truck is doing.
You also have to wonder why GM would install longer CV axles on their TB/AT4's with the 2' lift?
Edited by Fltmech
2" lift. 2' would require seriously long CVs. LOL
This is why this is such a great website. I have a 2 inch level and was about to order the 4 inch because your truck looks so good. Thanks for the info.
I put a Readylift 2” level and swapped out the 2” rear block for a 3” block on my AT4. So I have a total of 4” in the front and 3” in the rear.  I have not had any issues with noise or vibrations.  Very pleased with it so far.
Yes, because you already have the longer and/or beefier CV's.
  • 3 years later...
Hey I know im a few years late however I didn't find much when I searched for my build so I figured I would post
2021 Silverado Z71 RST
4in BDS coil over lift
OEM 18in wheels (came with the truck from dealership)
35x12.5x18 Nitto Ridge Grappler Tires
I ran 2in adapters to avoid tie rod interference
  • 8 months later...
Bumping this topic and will follow up with it in January/February. Just ordered a 2025 RST diesel 4WD, I do not want to do the 6" kits. I am in love with how the ReadyLIFT 4" SST Kit sits so I am going to make it work. After doing extensive research, CV angles are what's messing people up so my solution, based on online research, is upgrading the CV axles to the Trailboss/Z71 CVs which are longer than the normal 4wd CVs. ReadyLIFT makes a 2.75" Lift for Trailboss/AT4 trucks that give the truck a total of 4.5-6" of lift, so if those CVs can do it, I dont see why they can't do it for a 4" lift on a regular 4WD. I cannot confirm yet if this is the fix as the truck was recently ordered and expected to arrive in December. If any other person has gone through this testing of the trailboss CVs, let me know. More to come.
    MASONV88888888
    MASONV88888888
  • Who's Online   1 Member, 0 Anonymous, 1,623 Guests (See full list)
    • I have 2 choices.
