I'm wondering if I can swap the 4L80e from my 1999.5 GMC Sierra 2500 into a 2005 Sierra 2500 that is being sold with a "blown" transmission? The newer truck is in much better condition overall and is priced well.
Yes, you can swap it in.  You probably will also either need a new torque converter or swap the torque converter as well, as I recommend you not use the one from the blown transmission (as you don't know how well it works or what crap may be in it).
Note, this is specifically about the 4l80e.  The 4l60e is supposed to be much more specific, and has much more limited interchange options.
Edited by davester
  • 2 years later...
Yeah it should work no problem.
Also make sure the torque converter is properly engaged with the pump in the transmission AND that it doesn't come out as you are installing it.  If, when the transmission is bolted to the engine and the TC is pressed up against the flexplate and doesn't easily move (as in, pushing with your hand) back into the transmission, unbolt the transmission, move it back a bit, and then get the TC engaged with the pump again.  There should be some space between the TC and the flexplate when the trans is bolted to the engine, so you have to pull it towards the flexplate to bolt them together.
Failure to do this, you likely will destroy the pump in the transmission once you start the engine, necessitating removing the trans, replacing the pump, and cleaning metal bits from the transmission...
  • 1 year later...
  • 9 months later...
On 3/26/2024 at 1:50 PM, chev5535 said:
Will a 2002 4l80e work inplace of 2003 4l80e in a 2500hd 6.0 without changing internal wiring harness?
Did you ever get an answer? I know im going to need a new torque converter but i was wondering about wiring too
    250.3k
    Head Scratcher
    Head Scratcher
  • Who's Online   4 Members, 0 Anonymous, 416 Guests (See full list)
