21 minutes ago, Offroad9730 said:
Thanks for clarifying all that !
Do you know why these engines seem to consume oil?  I'm curious about that as well. 28,000 miles and very regular oil changes are done with good synthetic oil and WIX XP filters. Is it because of the OCM (oil control valves?)  I don't have any leaks and she doesn't blow the blues, but it must be burning it slowly somehow?  Is it because of the DFM, and oil gets past the lifters into the combustion chamber.  A guy would expect higher quality on such an expensive truck. I really liked that comparison chart on AFM vs DFM.  Thanks again.
On 12/31/2024 at 7:18 PM, Offroad9730 said:
Either way, I'm glad we have the 5.3 in the High Country with 10 speed auto.  I was also told by salesman that only the 4x4's High Country were 10 speed autos.  The 2WD were 8 speed.  Is that correct?
What model year are you / was he talking about?
GM has been changing which transmission usage since this thread was started.
I don't recall what year they last made a change -- perhaps when the refresh trucks came mid 2022.
For sure '23 and newer
- 6 speed is gone
- 8 speed is only used with the 2.7T
- 10 speed is used on all 5.3, 6.2 and 3.0 engines
Neither transmission has a dipstick.
6, 8, and 10 speed each call for a different transmission oil.
I never noticed that there was no tranny dip stick.   That's kind of odd.  I don't have any leaks. Thankfully.
It shows tranny temperature as normal all the time.  29K on truck.  I wonder what the interval is on changing fluid and filter.   Probably in owners manual
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 234 Guests (See full list)
