Chevy Mylink and android
Hey yall new to the site, joined so I could ask this question. I have a 2016 Chevy Silverado LT. I cant seem to get android auto to work or my phone to work with the mylink for that matter. When I plug in my galaxy s8 into usb and select project on the mylink it says I need to connect a compatible device. I read some where that I could use the wifi hotspot to put apps on the mylink but when I go under settings there is not a tab for wifi the only wifi options are under onstar. I bought the truck used so its had one owner before me, maybe they disabled something? I have no clue haha. Any help would be greatly appreciated. Thanks
I know this is a stupid question but did you download Android Auto to your phone?
Just to add, projection option will not work for the Silverado radios.
Sorry, one more thing to add. Not all of the 2016 Silverados came with the ability to get Android Auto to work. Mine was one of them. I had to take mine into the dealer to have a software update done. Once that was done, I have been able to use Android Auto ever since.
This ^^^
Haha it's all good, yeah I downloaded onto my galaxy s8. I saw an option for apple car play when I was going through the settings,odd that it would be able to do apple car play but not android auto haha but I guess it happens. When you did the software update how did you go about that at the dealership and how much did it cost if anything?
It says projection but it's a bit misleading. Its designed only for Android Auto or Apple Car Play. Here is a brief video that shows how it should work.
https://youtu.be/7wL8asQOf0Q
Like I mentioned, not all 2016's were set up for the Android Auto to work right away. Mine also had the "Projection" icon but nothing I would do got Android Auto to come up on the screen. It wasnt until I took it to the dealer and they updated the software on the radio, did it work...
Ok gotcha, so I guess I'll need to make a trip to the dealership. How much did they charge? I know it probably differs by dealership, were they able to do it some day or did they have to keep your truck for a day?
It was free when I had mine done. It was a new truck and I took it in within the first few months. For some reason. it will take a couple hours because it has to be downloaded first. I have seen where some dealers charge if truck is out of warranty but some have been able to have it done for no charge...
    Matt Parker
    Matt Parker
  • Who's Online   5 Members, 0 Anonymous, 857 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
