2017 GMC Sierra 1500 Denali POSSESSED Touchscreen
Daniel Vafa
POSSESSED  touchscreen within my 2017 GMC sierra Denali. Approximately two months ago my touch screen while playing music on the radio station began to switch stations on its own, First slowly and then rapidly with no particular pattern as it just randomly chooses different screens, Menu items, basically whatever the touchscreen has available it runs through most of them in no particular order. While doing this it also will change my digital speedometer to another menu item as well. Has anyone had this problem? Ive taken it to the dealership many times and the only solution according to them is that I need a new touchscreen but usually cost between $800-$1000, i’m hoping someone has a solution! Thank you
Welcome to the site.
Taking it you are out of warranty? Where is your mileage on the truck? Really no fix, either the screen is going bad, but more than likely it is your HMI module that controls most of the dash's electronics.
Lot's of post's on here about the same problem, maybe there is a fix?
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
