Yeah, that's my understanding. The newer trucks are 433Mhz vs the older 315Mhz TPMS. Putting these wheels on is costing me a small fortune, but so far, I'm still OK with it.
Open the doors for a few minutes to let out the heat. When you start up crack the windows until the air from the vents in cooler. Purge the heat held in the ducts from the dash acting as an insulator. Run the recirc once the windows are up. Pennies make a dollar. Use all the tricks. Even if you have tint, in an area like yours use those reflective sun screens.
Educate yourself. Use your Fluke and an thermocouple on interior temps. Hang it from the mirror. See how even the angle you park at has an impact.
The people say they are not needed generally say that because they say its mostly not oil the can has in it. Reading various threads, you'll see people say that the can heats and cools causing condensation. They say that even though there is some oil in the liquid you pour out, it's not enough to amount to anything. I used to run cans on my engines and I would pour out about a half a quarts worth of liquid during the OIC. However, I did not loose half a quart of oil during the same time frame. With that in mind, I stopped using them and said screw it. Right or wrong, that is the way I went.
Even if there is only a small amount, a can will help keep it out of the engine. Its not going to hurt anything to run it unless you forget to dump it.
Will it make a difference long term, who knows.
I miss the old school stuff. I have Xpel tent on every window in the truck. Sadly, FL heat said it didnt care. Granted, the system will still cool down the cab eventually. But man does it take a min. When you first get in you feel like youre the turkey on thanksgiving.
