Shift to Park Error Message 2017 2018 GMC Acadia
My 2018 GMC Acadia began getting a "Shift to Park" message in error a week ago.  This occurs when shifting into park and pressing the start/stop button to shut the engine off.  The engine turns off, the car is in park (won't roll away), but the vehicle will not stop giving an alert tone, the warning on the DIC says "Action Required Shift to Park", and the car will not fully turn off.  There is a TSB for this condition, currently PIT5616C .
I took my Acadia in to the dealer to have it repaired, and they identified it as a wire connection, and not the actual shift knob/assembly.  I have read and watched some informative posts and videos on this subject where other owners have identified a sticking switch within the shift knob itself, but that was not what the dealer repaired for me.  I have not had time to see if the problem returns yet.
One downside is that I am at 37,400 miles, so just outside of the warranty period.  My service adviser asked if GM would cover a portion of the repaid (which ended up being $467 + tax), but GM denied paying any portion, as is FULLY within their right.  I plan to make a little noise with GM to see if I can get them to fork up anything, but I'll accept their position if that's how it turns up (as it likely will).  There's enough info out there that I probably should have just fixed this myself and saved $400, but I was hoping that GM would have a moment of goodwill.
  • 4 weeks later...
Initial TSB for Traverse, Acadia and Malibu called for the replacement of the shifter assembly with a test of 50 cycles of the shifter to confirm it was the switch in the shifter. If so shifter was replaced. Later revision of that TSB called instead for only the replacement of the wire harness coming from the switch in the shifter based only upon customer complaint of a shift to park failure.
My early production Traverse did not have the problem, but wasn't waiting for it to happen after warranty expired. Made a complaint of failure and went to the dealer for replacement of the harness. While idling in the reception area awaiting service got the shift to park failure and couldn't shut down the engine. Service tech replaced the harness and it did not solve the problem which turned out to be a bad snap-together switch where the pip had broken off and it fell apart. Got me going again by epoxying the switch together until the replacement shiftre arrived for install.
Switch is not independently replaceable and dealer installed a new retrofit shifter with a revised switch which would not come apart easily. Seems these early production shifter mechanisms are a time bomb....maybe the new harness will save the original switch from breaking and maybe it won't. Once out of warranty GM could care less because the problem only affects the first few months of production.....later production models are not susceptible to this problem coming with a revised harness and updated shifter mechanism with a revised switch.
I have an extended warranty on my 17 Acadia and had that issue pop up last year, I didn't pay attention to what all they had to do since it was covered, but I thought the dealership said there was a sensor that went out in the shift assembly, replaced it and no issues since.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
    • Yes.  The 2.7 Turbomax has Active Fuel Management.  It is NOT the same as the V8s.  Totally different system.     Here is an article from GM when the 2.7 came out explaining the cylinder deactivation and the valve lift system.  Starts at the section called "SCS Valvetrain":   New Turbocharged 2.7L 4-Cylinder Engine Powers Full-Size Trucks – TechLink         This is an internet myth going around.  It was alleged that some 5.3s had this mystical 8th digit of the VIN as an "E" which somehow meant it had a new one year only 5.3 that didn't have DFM.  The writer of said article and the person that made the claim conveniently can't count because they posted the VIN.  The 8th digit was a "D" which meant its still the 5.3 with DFM.  The 9th digit of the VIN was an "E" and the 9th digit isn't the engine code.  At all.
