Window Help
I have a 1999 Chevy Silverado 1500. I need to know what are the characteristics of either a bad window motor or the regulator or both. Will someone please help!
Grinding/scraping/clicking noise in the door itself.
Window jumps track.
Motor drags n won't raise the glass all the way.
Fixes...
1st grease the rollers in the track check for a smell from the motor
While rolling it up n down.
The Blue Mule
Window jumps track.
Fixes...
The Blue Mule
Thank you
Still a bit unclear whether just the motor and/or the regulator. Windows firmly in position. No squeaks; scrapes or anything like that... just the regular noise of the window going up (same noise as when it was new with one caveat that the struggling/slowness of the windows is audible and visibly present when going up). The noise/slowness is present going down as well but no where as much when the windows are going up.
Take the door apart.
Lube all moving parts.
If it has a problem moving, motor.
Process of elimination.
9 minutes ago, m&jtrans said:
^^^Basically what I said^^^
The Blue Mule
Yes
Tried to make it easier to understand being he still was confused.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
