I want to mount an amazon auto in the upper dash tray area.  It's the perfect spot for one, so that got me thinking a couple of USB ports would be cool too.   Has anyone taken that tray out, found any good spots for tapping into switched power ?  (or a route to the passenger side fuse box).
thanks
Uh oh, I can’t be the only one that wants to see what’s under that tray ?  Has anyone else removed it ?
Nice ride, I looked at a red trail boss, it literally glows.  They did a good job with color depth in the paint.
Im hoping someone comes up with a tech document on that tray, but my trim tool is calling my name...may do some surgery this week.
Would have been nice if they included some kind of power port up there. A usb charging port has to cost very few cents.
Seriously !  I bought a couple of direct wire 12v usb devices, one that is a single USB port and another that provides a mini usb for a dash cam.  About $10 on Amazon.
Also ordered the Gen5diy tap for the mirror power, but it ships usps slow motion mail, so who knows when it will arrive. That has an RJ11 connector for a radar detector and a 12v wire set.
so I’ll put the mirror tap in and power dash cam and have the option of putting another usb/or 12v device up on the overhead console.
still doesn’t solve the dash tray issue though.  Does anyone have a parts diagram of the upper dash or know where I might find one?
  • 4 years later...
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
