I've tried searching all over for some info on this but has anybody used the Kryptonite UCA's on a 17-18 1500? trying to find some feedback on it since it looks comparable to the cognito UCA's. If I somehow totally missed a thread on them then my bad. Just looking to finalize my parts list before i spend money on my suspension.
 I'm torn what to do for UCA 's myself. I have my lift kit and tires 37's (McGaughys 7" to 9"running at 9") sitting here in boxes. But still not decided on UCA's.
What are the stats on your lift/tires? Where are you getting everything?
I always thought of Kryptonite for 2500 trucks. You just don't see much of their stuff on 1/2 tons. Could be just me not sure  That being said they look similar to McGaughys but the ball joint is bolt in. Easy to replace.
McGaughys is pressed in. But I think the ball joint is better. Especially if you run it in the winter (salt).
Kryptonite is the same price as the Cognito at around $500.
I wouldn't be afraid to run the Kryptonite's or the Cognito's. They both look strong.
I just can't decide if I want to keep mine all McGaughys or jigsaw puzzle it. Grrrrrr
Edited by dieselfan1
I'll be using Bilstein 6112's set at the highest setting in the front, 5160's in the rear for suspension. Wheels and tires looking at 18x9 +1 offset fuel blitz with either Cooper ST Maxx's or nitto ridge grapplers in a 275/70r18 E1. Just trying to decide what UCA to use is the last piece of the puzzle. not a high lift more just setting it up for a better ride with some offroad usability.
I have Cognito UCAs and the ball joints wore out. I ended up replacing them with a set of Kryptonite ball joints. I haven't had any issues with them and they have a lifetime warranty. Kryptonite didn't have UCAs for 1500s when I got my Cognitos. If they did I would have gone with them. Its nice to see them offer more for the 1500s. I'll probably end up getting a set of their tie rod ends.
Sent from my SM-G975U using Tapatalk
What are you running for a lift?
Readylift 7 inch.
I'm liking the Kryptonite's.
I really like that the ball joints are easy to replace. And do the ball joints really have a lifetime warranty?
Sent from my Pixel 3 using Tapatalk
They say they have a lifetime warranty. I ordered directly from Kryptonite so they shouldn't question it. It's been a year so far and no slop in the ball joints. The cognito ones failed within 6 months.
That's what I wanted to hear. [emoji123]
I emailed Kryptonite with a couple questions. Got an answer from
Josh within a few hours.
I'm going to order a set on Monday. The ease of replacing the ball joints sold me. Plus he said they will be coming out with a lower control arm replacement very soon. Even though I only have 23,000 miles I'll be checking my lower ball joints before the lift goes on.
I want to thank ATXsilverice for asking about these . I probably wouldn't have even considered them.
Their stage 3 level kit looks very interesting as well.  Seems to be good stuff at a reasonable price.  I may be reconsider my current plan of 6112s and 5160s and just get their full kit with ucas and fox 2.0s.  Seems like I'd spend the same or more by the time I added UCAs and the rest of the front coil over parts to make the 6112s a complete replacement assembly.  I wonder if they give the lifetime warranty on the shocks as well?
Lifetime warranty on Kryptonite parts. No Questions asked.
Fox would have their own warranty.
That's a good price on that kit too.
Well it looks like based on everything (including the pictures posted up by dieselfan1) I'll be pulling the trigger on ordering these. Now its just a waiting game for the rest of the parts to come in as well.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
