Rear Wheel Seal
Ok, I have a seeping rear wheel seal on my 2012 2500hd. I understand how these things come apart (I've had my share of Dana 60s/70s/80s apart).
What I can't determine from the WWW is what size the axle nut is (what axle nut socket do I need), whether it is a one-time use nut (nyloc) (do I need to order a new one), or the torque strategy for installation (example - Dana are torque to 140 ft-lbs and back off 120 degrees)?
I want to make sure I have everything ready before I start tearing into it. Can someone point me in the right direction?
Sent from my SM-G950U using Tapatalk
The full service manual will describe the tools needed, whether you need to buy a new one each time, and how to uninstall and install it correctly.
Paper version at helminc.com/ebay/amazon, or online (cheaper) at alldatadiy.com  or other sites.
You need the 9-point axle nut socket (Lisle brand makes one; other likely as well). It's not required for removal of the nut, but you'll need it to set preload. It is a re-usable nut as well, though the SI indicates the retainer isn't (for some reason). The installation involves torquing to 52ft lbs (same spec as older 10.5s), loosen, and re-tighten finger tight until the key-way lines up.
This in a condensed instruction, since it sounds like you've done this stuff before.
Ok, I see that nine point socket and have it ordered, but I read a review that one guy had a 10.5AAM that was a six point? Was there such a thing?
Yes, the 2010 and older 10.5/11.5 axles used a 6 tabbed/ point socket, very similar to the newer 9 point socket.
Perfect, that clears that up!
Thanks for the information, I'll get a seal locally so I can compare/exchange them if needed. Otherwise, if it is a similar setup to a Dana, should be a straight forward process to R&R.
Thanks!
    • 2024 l8t . Ac has never felt really cold even new. But lately it seems a little warmer. When it gets in the upper 80s and a little more humid it just does not keep up. And sometimes at idle it gets warm. My wife's 2008 envoy is better. My son's 2016 is colder. I have an apointment for a third try Monday the 29th at a third dealer to try and get cold ac before my warranty is out. The first two told me something about so many degrees under ambient temp blah blah blah seemed like they didn't want to mess with me. This was set at low. Max air fan speed high. 87 degrees and a little humid.   .
    • It isn’t all that bad in the world with purchasing power versus quality. My first car had just basic equipment. My oil choice was conventional oil. The life expectancy was around 100K miles. During that time you could expect to change all the accessories. Today with inflation you can buy the equivalent. It comes fully loaded with 4 doors. The life expectancy passes 100K miles replacing no accessories. If reaching that milestone is your goal you simply follow the recommended service intervals. If you want more miles simply do more maintenance. When in doubt you can check the internet or YouTube for information. The selling of any product hasn’t changed since the beginning of time. The power of the buyer has. The price of the product hasn’t changed much with inflation. The buying public wants more. Competition and the buying public has put the sellers in a box. The greed is on both sides. You can still get more for less. You just have to do with less. That used to be popular. The buying public has changed . It’s the sellers that are trying to keep up. As Grumpy tries to inform the readers in this case with maintenance. If you want more. More effort is required. That information wasn’t available this easily just a few years ago. I believe the public has more power. Getting information is easier.
    • Gentlemen, I'm new to this forum. My question is, I thought I have read somewhere that the rear wheel liners for 2024- 2026 GMC Sierra HD3500 DRW can/will fit the 2023. I can't seem to find that information again and wondering if anybody has any knowledge if these will work or not with the 2023? Part# is 84892542. Thank you for any information. The GMC parts counter wasn't able to give my any definitive answer?
    • Spacers aren’t safe anyway, so you’re better off just buying something else.
    • Its because they have thread locking compound on them. I would bet money that they are actually reusable and not a literal TTY bolt because GM and most other OEMs don't trust techs and the end-user to apply thread locker properly in the same way they don't trust anyone to solder properly (and instead instructing crimps everywhere). Torque To Angle =/ Torque To Yield.   If you think dealerships or any technician replaces every 'discard' bolt in every procedure, I have a bridge to sell you.
