4.8/5.3 quality rebuild or 6.0
I'm starting to do some research on replacement engines for my Silverado, kind of planning for the future of sorts.
Ive browsed the web and found that Chevrolet wants nearly $4k for a long block 5.3 about the same for the 6.0 I believe
I was wondering what as a ballpark what it might cost to rebuild my 4.8L with quality components vs buying a non-DOD stock 6.0 new, or sourcing a 6.0 and rebuilding it to stock specs
Naturally aspirated 4.8/5.3 build starting with my 160k mile LR4
New seals, pistons, rings, lifters, pushrods, etc or a mix to high quality rotating assembly possibly Summit of Eagle?
223/226 .600/.600 111 LSA Texas Speed Performance truck camshaft package (maybe something a bit tamer) with beehive valve springs for Cathedral Port Heads
ARP hardware, New timing set
Or a 6.0 with stock all new internals,or new GM crate 6.0 (if they are even still available) Any idea of a price difference on these. I'm rather new to this and running into a lot of conflicting information.
I'm wondering if it's worthwhile and more cost effective to rebuild my engine vs buying a rebuilt unit from GM. folks say it's wise to just get a 6.0 and rebuild that but I'm unsure of the cost on doing that as well. . I'm wondering what a reputable shop should charge to do a build similar to what I described above.Rebuilding my 2003 4.8 with a hot cam and upgraded internals and all new wearable components. or rebuilding a 6.0 to exact stock specs.  Parts plus labor. I am open to suggestions and omissions
Thanks
What's wrong with your current engine? Just worn out or needing more power? How many miles are on it? My work truck 4.8l has 315,000 on it and runs great. It's not a mini Cooper. 150,000 isn't high mileage for a 4.8/5.3.
I would think that there is at least 8-10 shop hours just in removal and installation of the engine so guess $1000 in labor for that. Probably somewhere I the neighborhood of $700 in machine shop labor on the block, another $200 on heads. Probably 8ish hours in disassembly and reassembly of the block
That's about 3k in labor before you have got any parts. My cam kit was 800 with lifters and springs.
You can get a rebuilt long block 5.3l for right around 2k. If you want 5.3, get a 100,000 mile salvage engine and put it in.
I'm just planning for the future I'm restoring my 2003 Silverado. I'm selling (attempting to sell) my 3rd gen Camaro to further fund my quest. There isn't anything particularly wrong with my engine...I was just wondering the cost of doing what I mentioned and you did a great job of clearing things up for me.
I've got so many things on the list I want to do/have to do to the Silverado, none of which alter it from stock offering very much. I just want to bring her back to her former glory.
I just bought my truck a few months ago and although its a really nice truck the previous owner clearly didn't see the potential and probably used her for mainly work. Nothing wrong with that, but the PO most definitely didn't do proper maintenance and that's creating a lot of work for me. That's almost a good thing because I'm learning more and more about these trucks everyday both from these forums and actual hands-on repairs.
So far I've done spark plugs, wires, oil change, headlights, LED bulbs, air filter (OEM), vent valve solenoid, hood lift hinges, driver's seat foam replacement.
Not much I know but I'm just getting started.
My next items on the list are transmission service (not flush), rear differential fluid change, shocks and steering rack and new front bumper supports, and valance, air raid intake tube into stock air box, injectors, 02 sensors, exhaust.
It's really been a lot of fun and every project is a definite learning experience for me.
Thanks for replying!
