Digital Gauge Display
My 2016 Denali Digital Gauge cluster was changeable between 2 or 3 options.  It essentially changed the look of the digital gauges, the colour and where some things were displayed.  Is there an option similar to this on the 2020's?  If so, would someone mind taking some pictures of the various options?
Thanks.
Thanks.
Only thing that changes is the volt gauge changes to a transmission temp gauge when you are in tow/haul mode. There’s nothing else you can change with the digital gauges themselves.
I really wish they would bring it back. Gave you a sense of customization and what not.  Hopefully they bring it back for next year or 2022s when I'll be getting a new truck.
Thanks.
2020 Acadia Denali ('refreshed' for 2020) still has the optional cluster configuration feature.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,123 Guests (See full list)
