00 blazer battery problems
RyanbabZ71
Please leave this post in the general section so more people can see.  If i put it in the S-10 section i wont get many replies
Well here it goes.  About a yr ago while drying my moms blazer i had the radio on (10 min tops).  Well battery died.  Charged it and all was fine.  2 months later she did the same thing.  Charged it and it was fine.  Well this morning she tried to start her blazer for work and it wont start (battery).  She played one song after she washed her truck yesterday.
The green indicator is still there when i had run it down the green was gone.  I am charging it as we speak but she is pissed and wants a new battery.  Truck is way under the 36K warranty and has till the end of august for the 3 yr.  Will chevy cover this?  I thought hers has battery run down protection  It currently has an AC Delco Freedom battery
Thanks
They may not cover the battery itself, but they should cover anything that is causing it to drain down.  They may cover the battery, not sure though.  I would think it would fall under the same catagory as fluids/filters etc.
Had my dad call the local dealer and they said this shouldnt be happening.  They are going to fix it.  Just gotta get it started and take it there now
Ryan,
I've seen batteries do this before, and still give you the green "eye", especially if 1 or 2 cells are bad, they can drain off the others.  Could be something else also - particularly if you have this happening w/ a new battery . . . .
Have them check your alternator output, voltage regulator and connections also, if they will do it.  My Olds dealer replaced our battery @ ~28K miles on the Alero - it just up and died one day w/ no warning whatsoever.
Good luck.
Sounds like a bad cell in the battery.
The green eye may still be working, but you could have a dry, shorted out, platelette deprived cell over on the other side of the battery.
If you can't get to a GM dealer, you can even go to Napa, have them put a load on the battery with a load tester and it should be able to tell you immdiately if a bad cell is present.
If the battery is eliminated as the problem, are you sure it's not the starter?  GM truck starters are notorious for getting the brushes hung up.
1 hr to rechagre and i drove it to the dealership.  They are gonna check it out and also change the oil (my dad wanted it done)
Will find out tonight what is wrong
We had a bad platelette in the battery on one of my Olds.  GM paid for the tow, and the new battery!  It was so badly shorted out i couldn't get it to jump off the truck.  I never even tried to charge it...
Got a new battery today.  One in there was bad.  Said it is covered for 5 yrs
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
