Deep "Howling, Roaring" sound. Need opinions.
Just bought a 2006 GMC Sierra 1500 Z71. Fully loaded truck. The only issue I have noticed is a howling or roaring sounds while driving. You can hear it while driving 15+ and hear it more prominently when decelerating and coming to a stop. It is very audible and gets louder as you drive and turn left. Was thinking a wheel bearing because to me it sounds like its coming from the front end. Someone suggested that my differential needs replaced. Truck goes in for an inspection at my local chevy dealer on Monday. Just looking for opinions in the meantime. Thanks in advance!
Perhaps if the actuator in the front diff is stuck in the "enabled" position, so the front diff is stuck in 4wd mode (so the wheels are spinning the front driveshaft), it might make that noise, or if the diff is empty of fluid.  It's less likely if the diff is filled and not locked.
Easy check if it's locked is to just reach under the truck and try to spin the front driveshaft (with the truck in 2wd).  If you can't spin it, something is wrong (again, most likely it's the actuator in the front diff, but possibly parts are broken inside as well).
but front hubs are a good first choice, particularly if the truck is over 150k miles.  Or possibly CV axles, if the boots on them have been damaged so the grease can get out/dirt can get in.
And since this is a new-to-you truck, I would suggest
-replacing all fluids (oil, transmission fluid, transfer case fluid, both diffs, coolant, power steering, brake fluid)
-check the brake lines for rust (easy spot to check where they go bad where 4 lines run along the frame from the driver's side front wheel to the abs controller under the cab).  The rear line also tends to rust bad where it runs along the frame above the fuel tank, but it's hard to see there.
-check fuel pressure at the fuel rail on the engine.  Should be right around 60 psi (+- a couple psi), both at idle and when the engine is revved up to 3k rpm.  If it drops and doesn't quickly return to full pressure when the rpm levels off, your fuel pump is going bad...
-depending on mileage, you probably could replace plugs and wires
And if you do all that, you probably have too much money, so send me a couple hundred... ?
Truck has around 147k miles. The CV axle boots looked to be in good shape. I did test out the 4wd system and it all works, seems kinda loud but works. Is it possible its not fully disengaging when switching back to 2wd? I will see if the front drive shaft is spinning freely in the morning.
Probably a hub needs changing.  Check out this video, FF to 1:06 and have a listen.  One of our Montana's hubs sounds just like this!
Honestly it sounds very similar. It sounds very much like that while turning left at speed. Not that loud going straight, YET. I'm really thinking thats what it is and being that it gets louder as you turn left I would assume its the passenger side. Only thing that made me question myself was when someone suggested the differential gears as I know those can make a similar sounds when making turns when they go bad.
If you want to check (after checking that the driveshaft rotates when in 2wd) if it's the front diff, you can just remove the 2 cv axles and drive around a bit with them out.  If you still hear the sound, it's the hubs.    You can also try spinning the axles in the diff and see how they feel/if they make any sound when you spin them.
If you're hearing it while turning or taking curves at left going down the road then it's most likely the right hub. Very easy diy job with metric tools. Don't waste your money at the dealer and get a Timken wheel bearing if possible.
Easy way to check is jack the wheel an inch or so off the ground and grab the top and bottom and push the top in while pulling the bottom out or use a pry bar a couple ft long and put it under the wheel and pry up while resting your other hand at top of tire and rock it as well. If it moves verify whether it's the wheel bearing or ball joint.
You can watch the ball joint while having someone rock it or prying it up and down. Did many of these hubs. Bring a big hammer for removal. IF you need torque specs P.M. me your email Addy and I can send a sheet with them on it to you plus a few other pointers.
IF you're not comfortable doing it you can get it done with the same warranty a dealer would give you at most reputable aftermarket franchise or local repair shops.
They can do fluid flushes as well. 75w 90 on the rear differential. You don't need synthetic unless you want to waste your money.
Check your u-joints as they're known for going bad as well.
Check the differential rear cover for any leaks. IF you see wet fluid and the seal isn't wet then Google GM or Chevy Transfer case "pump rub" or read this article,
https://www.merchant-automotive.com/Transfer-Case-Pump-Upgrade-Kit
Great company. I upgraded the pump 5+ yrs ago and replaced the rear housing as it had rubbed thru. Had the local trans shop check all the gears and they threw a clutch pack in the transfer case. IF you have auto setting for the transfer case then never use it as the clutches slip and wear faster vs using the 4hi when needing 4wd in snow / ice such as what I use it for here in South Dakota.
For the transfer case fluid use the GM stabilitrak as they have friction modifiers in it. Transmission shop even uses it on the 01-06 year models. Most reputable parts houses will sell the GM fluid as well if they don't have on floor just ask.
Go thru and check all the other suspension parts while you're at it and if the front shocks look worn then replace them. The rears are a different story so check what you have and the cost of them as mine are the premium ride and cost at least a few hundred each. Yes it's a Tahoe but same platform in many ways when it comes to the frame assembly.
Sent from my SM-N975U1 using Tapatalk
...just a not on dtnel78's post, "Check the differential rear cover for any leaks. IF you see wet fluid and the seal isn't wet then Google GM or Chevy Transfer case "pump rub" or read this article,"
It should be:
Check the transfer case rear cover for any leaks. IF you see wet fluid and the seal isn't wet then Google GM or Chevy Transfer case "pump rub" or read this article,
You can also get a much cheaper pressed-metal plate instead of that billet pump, and it works just as well.  You want to either check with the previous owner if one of the fixes has been installed, or crack it open and install one, as when the pump finally rubs through, the TC fluid comes out while you are in motion, and doesn't leave a puddle under the truck, so you notice the problem when the TC is making noises indicating it wants to be rebuilt (much more expensive).
And, while pulling on the front wheels at 6&12 and having movement in the hub indicates the hub is bad, it can still be bad/making noises even if it doesn't show any movement.
    jrogjr
    jrogjr
  • Who's Online   2 Members, 0 Anonymous, 415 Guests (See full list)
    • Average Assembly 4.8%   That's the likelihood of a light duty vehicle reaching 250,000 miles. Link below has the stats on this. Among pickups the 350 series (Dodge)  and higher (450 Ford) are most likely and nothing American built in the lighter trucks pegs a number higher than the overall average.  200K and up is the stomping grounds of Asian vehicles. Toyota Sequoia the leader at 39.1% probability.      https://www.autoweek.com/news/a68886903/vehicles-most-likely-to-last-over-250000-miles/   Likelihood drops dramatically at 100,000 miles of reaching even 150,000 miles. 250,000 is deep in the tail of the curve.    I've been told by the 'experts' that I don't need oils of the caliber I use. My high viscosity is damaging my motors. Ash content it to high and WILL foul plugs and kill cats and O2's. I don't need that much ZDP; my choice is over added and not cutting edge. I change it to often. I baby them to much.    Three Honda's reached 200K + and none used oil. All Red Line motors. All sold to friends or family. One Toyota reached 300K using oil, Pennzoil. Dizzy 300K using QSUD until it cashed the rings at 80K then whatever but often ever since. Did you know this engine still sports the OEM timing chain and is dead silent? Pepper spitting into the wind short of 200K, Red Line and changed often. Uses zero oil. A HPFP and a pinion seal. Still using most parts it left Fort Wayne with. So 50% of my vehicles have gone past 250K and 100% of the last half dozen past 200K. Of these two using "shelf oils' did so using abnormal oil and the four that used a premium boutique oil did not. There might be something there the experts have missed. 🤔
    • i dont know where you been reading...they make a top notch product..people say lots of great things about them..yes it can be difficult to get a hold of them when you need help sometimes put when  you do it is great service...   as for the actual question at hand i have the ccv mod and i vented to atmos in my case...I got my ccv from somewhere else but i have plenty of VSE product...for starters i use their tuning on my 22 duramax
    • It's not that it sits for extended periods. I drive it every couple of weeks. However, I did consider draining the DEF and replacing it.    Don't you get a "Poor quality DEF warning" if its bad?
    • Try draining the def and relacing with new if it has been sitting for a long time. Def does go bad after a little while.
    • Thanks @Viktorrocks15 if you are still out there.   I followed your instructions and worked out great, went to the scrap yard and procured 2016 escalade cluster, hud, bezel, and switch. Got lucky and found a Camaro in the u-pull with the HUD bezel.   I made my own harness with these diagrams: https://www.gmupfitter.com/wp-content/uploads/2022/10/23_Escalade_Escalade_ESV_Electrical_Body_Builder_SM_en_US_2022OCT25.pdf   I used escalade cluster because its the best one that will work IMO. Still need to get it programmed but it looks really good.
