Transmission fluid change
I have a 2018 Tahoe with the 6L80 tranny. Did it come from factory with Dexron VI? I have 21k miles on it and it’s still clear /slight pink.
Yes
3 hours ago, BlaineBug said:
Maybe I was being harsher on my fluid than it actually is.  At 35,400 miles presently.
I believe I would ignore the seriously dirty portion when I wiped the entire length of the transmission dip stick.
The two other areas are soaked into the napkin somewhat but are more representative of the fluid that comes from just the very tip of the dip stick that is submerged in the pan.
I wouldn't say it's bright red but looks relatively pink.  Davester's looks worse.  It's probably a bad idea to wipe the entire dip stick when going for a measurement of color.  Even clean metal leaves a residue when it's wiped.  Not sure why that is but it happens.
It's the clutch material, it goes up the dipstick tube as a dust and coats the tube and dipstick. Mine has it too.
Makes sense.  Although it doesn't seem like it matters what or where metal is, if it's raw and un-coated it will give you a sort of residue if you wipe it with a rag or towel.  Not exclusive to dip sticks.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
