Sold the old crusty 22s. That put $1k towards the cam swap. Back to OEM 20s. It drives and feels much better with 20s to be honest. I still want another set of 22s though...
At this point it is no longer my daily driver. I got a Chevy Volt because I'm driving a lot for work and it saves me money. So the truck gets to stay super clean and detailed 24/7 and stays inside. I take it out any chance I get when it's not rainy. So much easier to keep it clean that way.. any time I take it out it looks like it just came off the showroom floor.
  • 7 months later...
2 hours ago, langston1726 said:
Whats the part number on your Xr1? Got any more sound clips?
Part number 40575
1 7/8 long tubes to X and dual 3” pipes  with two Borla 40575 dumped before the axle.
Here’s one that I think was a cold start if I remember correctly. I’ll get another driving one uploaded soon too.
9 hours ago, davis86t said:
Part number 40575
Sounds great I just ordered the 400372 multicore which is a 17” oval case, I believe yours are 21”. Hope it’s not too loud with my TSP headers😬. Sounds like these get pretty rowdy on some throttle. Any drone with these?
Currently running a 19” Borla ProXs. It sounds pretty good but looking for just a little bit more rasp.
Edited by langston1726
Yes there is a bit of drone, mostly around 2K rpm depending on load, but it’s enjoyable for me, not bad at all. My wife doesn’t like it though. But she drives a Tesla so.. 👍
I personally hate too much rasp and it seems like with my setup I’m constantly feathering the throttle to reduce it. Unless It’s WOT — it screams like a drag car then, and it’s all worth it. Haha
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
