Maxlife oil
Black02Silverado
:cheers:
Free oil? Don't wanna let the wifee see this as I just spent $54 to change the van and truck sunday. This would be a really sweet deal for some folks. Thought I would bump this as it is good info.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 800 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
