Igniton On Without Key In Ignition
I am a fleet technician for a private ambulance company. I just recieved 2 2008 Chevy Express 3500 with the 6.6 Duramax. One of them has an issue with the ignition staying on after turning the ignition off and removing the key. Replaced ignition switch and relay. Can anyone help with this issue.
As a fleet technician, you don't have access to the full-service manual for it?  The FSM will have the diagnostic procedure for figuring out where the problem is...
What do you exactly mean the ignition stays on?
The engine stays running with the keys out?
The engine turns off but the radio stays on?
.02   Maybe the diesel is "dieseling".
Early emissions days with hotter running gas engines, they would sometimes "diesel" or "afterun" with ignition off and key out. Usually a change in timing would reduce cylinder temperatures and prevent combustion after spark was cut off. Shutting the engine off in Drive instead of Neutral of Park loaded the engine and it usually prevented the condition also shifting to Drive with key in Accessory would stop the dieseling engine..
Never worked on a diesel but know they contain glow plugs for initial ignition and high compression heated combustion afterward, so no spark to cut. Could be the ignition off fails to close air or fuel to the induction system to shut off the engine.
BlancoSilverado,
The engine turns off and everything else turns off except fuel pump and SES light.
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 544 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
