Going 12 Wide is the challenge.
Found Options for you on Custom Offset's Page.  All of these photos looked leveled.
None of them are on stock wheels.
https://www.customwheeloffset.com/wheel-offset-gallery?wheel_diameter_from=22&wheel_width_from=12.0&tire_height_from=33q&sort=date&year=2019&make=Chevrolet&model=Silverado 1500&drive=4WD
Yeah. I got a 2 inch ready lift level now. Looks like 12.5 wide is impossible without spacers or or aftermarket wheels. Really wanting to keep my stock 22s tho. I’m hoping 285/55/22 will fit.
  • 2 years later...
I have the same problem. I have 2022 1500 RST and had the trail boss lift kit put on by chevy. The height isnt an issue, Its the space between the tire and upper control arm has only about 1" clearance to the OEM tire which is 275/50/22. You would need a 2" centric wheel spacer. Important to follow the recommended torque specs which i believe to be 140ft/lb. on both spacer and wheel.
