Trans Temp always HOT
2 minutes ago, Grumpy Bear said:
" Normal"? The question has two faces. One asks if the noted temperature is within that models design parameters. The other asks if it is optimal. The answers to both are surprisingly simple.
Does it have a thermostat? If the answer is yes then yes it's 'normal'. If it does not have a thermostat then no, it's not normal.
Is 190 to 200 F optimal. Depends. If efficiency is your goal then yes. If longevity and reliability are the goal, then no.
Only the OP can answer any of that. He has to look and then decide what is more important to him. Fuel or reliability.
:chill:
Reliability is the goal
  • Replies 33
On 4/4/2020 at 11:55 AM, Brandin Boisclair said:
My friend has a 2011 1500 and his 6L80 runs around 150-160 which seems MUCH more normal. What do I say to the dealers about me wanting all that done? I assume I have to pay for all of that as well? And what is the benefit of replacing the converter after all of that is done?
Is there glitter in the transmission fluid?
Then give this a try before you commit to a rebuild. If the fluid still looks nice and clean and pink. Flip the pill in the thermostat and add a bottle of Lubegard Red. You'll know in about a hour. Minutes maybe. IF the fluid is anything but...the draw a measured amount of fluid from the dipstick and in like volume replace. Drive 50 miles and repeat. Do this four to six times or until the fluid looks good again. Then add the Lubegard and do the pill flip.
If none of that works then you might very well have some mechanical damage. Then would be the time to commit. IF so might I be so bold as to suggest a GM Remanufactured instead of a francize trans shop. Rebuilders replace clutches and seals. GM Reman's are back to blueprint specs and have a real warranty.
Wishing you the best outcome.
Fluid looks good no glitter
    Bigo1112
    Bigo1112
  • Who's Online   5 Members, 0 Anonymous, 979 Guests (See full list)
