Trans Temp always HOT
Hey everyone,
I’m new to the forum. To start out, I have a 2014 Silverado 1500 5.3 with 65k miles. I’m on 33x12.50 tires and factory gearing(which I believe is 3.42 or 3.24, something like that). I’ve noticed my transmission temp gets hot all the time without towing or driving like an idiot. I’m running around 194-199 driving 80 on the flat interstate with ambient temperature around 60-65°.  The trans is also starting to develop a small flare between 2-3 and 3-4. My local shop said the trans is starting to fail and it didn’t have any codes. I wanted a second opinion so I took it to a reputable transmission shop in town. He told me it was the torque converter starting to fail and that I should replace it and be good to go. He said he has seen this problem before on the 6L80’s and it will fix it. I just figured I’d ask y’all before I pay $1000 to have the converter replaced. Thanks!
  • Replies 33
I am no expert but those temps are 'normal' for these transmissions.  This is why many of us do the transmission thermostat delete mod. After I did this, my temps never get that hot anymore.
I don't have any ideas on your shifting issues. All I'd suggest is to do a full transmission fluid change.
Good luck!
its not normal!  correct temp should be around 120-160
if your getting flair, take to dealer and have them do the recalibration on the TCM,  there is also an ovehaul cleaning procedure that the GM technitian can perform which basically is a self cleaning procedure of the valvebody solenoids and and air/fluid purge of the Valve body curcuits  .. after this it will drive normal again.  but i would recommend driving the truck in M4, and M5 mode until its corrected
then after this , get the circle D torque converter with OEM stall speed
36 minutes ago, gone_fishing said:
194F is normal as thats the thermostat bypass setting.
must have did it wrong or your drag racing
My friend has a 2011 1500 and his 6L80 runs around 150-160 which seems MUCH more normal. What do I say to the dealers about me wanting all that done? I assume I have to pay for all of that as well? And what is the benefit of replacing the converter after all of that is done?
2014-2019 trucks got the thermostat. early trucks ran cooler trans. its all about getting you into a new model truck when parts cost is too high to repair
if your cheap, you can have a mechanic, take out the thermostat pill, turn it upside down and reinstall, I heard this also works,  lots of YT vids on doing it correctly.
the converters are poorly made in the 8 speed trucks,
 i have 6 speed and not seen any issues yet, if you have vibrations in drive line  the converter is probably failing .  shift flair is not torque converter related, its software tuning and the computer learning your driving style. but this is not 100% . high temps may have degraded parts in the converter and cause a failure.
gm mechanics will not modify your thermostat. deff have the gm techs do a trans recal and check the trans filter for excessive metal debris to confirm parts are ok
2014+ 1500s run around 200 degrees. This is normal no matter how much anyone says otherwise. Whether it is good or not is another matter.
Just normal highway driving and up to full operating temp I usually see between 192F and 196F on my 2014 Sierra 6 speed. I think its been established this is normal for the 6-speed K2 1/2 tons (assuming you are stock and haven't modified the bypass valve).
operating at 200+F will dramatically shorten the usefull life of all the components inside your trans.  100-150,000 miles is all you'll get in city driving
No one is saying that 200 is good for it. Just saying it is normal for these trucks. Well aware that newer 6L80s don't have a great reputation for longevity.
Anything over 215-220 is where fluid life drops. Fluid life has always been just fine at 160-200 degrees.
My truck gets to 180-190 after a while of driving.
The OP should do the thermostat mod and see what happens. Your temps will drop 20-30 degrees easy.
190-220 degrees wasn't normal back in 2012 trucks, they ran at 130-160 normal driving conditions.  it's not just the fluid life you should be worried about.. lots of the components that make these transmissions function are made of plastic and rubber. once you hit 180-220 degrees you are just oxidizing and hardening all these soft components that maintain the sealing and pressure to control of the fluids mechanicals function to do its job.,  overtime these soft parts will disintegrate like a set of old wiperblades trying to squeeze water off your windshield,  it just aint gonna work right
What in the hell are you talking about. Every single v8 truck from 2014-2018 has this thermostat and they all operate at 190-200 degrees.
why would you post such blatantly incorrect jnfo
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
