Anyone out there have the Nitto Ridge Grapplers  285/5022 or 285/55/22 on stock 22 inch rims? If you do I would love to see some pics, thank you.
Hey Drew, thanks for the pics , truck looks great !!  so If I go with the Trail Boss lift I may have to go with the 285/50/22 `s the ridge grappler is a little taller and you have a 3 inch lift,
Another member put on the gm lift and was able to clear 285/55 r 22 ridge grapplers and had no rub and no trim. Here's a Denali with just a level, and a Chevy with the GM 2" lift.
I think the Denali rubs slightly because of the squared off fenders where the Chevy is more round
Nice !!! Love to see more pics of the black High Country , does that have the Chevy wheels ?,  if its possible , thanks for the responses .
Those tires appear to be somewhat slim from this angle. Can anyone confirm if the black Trail Boss with black wheels are 285/55s or if they are smaller than that? Maybe 45 series?
Just to give some reference, here's an LTZ with 285/55 Terra Grappler on 22s with GM 2" lift.  No rubbing with clearance for more.  Ridge Grapplers would fit well...
Glad I found this forum... I was looking to replace the stock tires on my 2020 Sierra Denali and did not want to do a lift or leveling kit.  I ended up going with NRG's 285/50/R22 last week.  I'm happy so far.  It's a different ride from the crappy Bridgestone Alenza's.
Cheers,
JB
Cheers,
JB
Did you notice a difference in ride quality going to the more aggressive at tire?
    bellssn690
    bellssn690
  • Who's Online   5 Members, 0 Anonymous, 509 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
