Fog light not working
My passenger fog light is not working.
I believe when I got in the accident, and the bumper end cap got ripped forward it damaged the plug the fog light uses.
I checked the wires with a volt meter, and there is power going to the plug, but the new light bulb plugged in doesn't work.
Can I get a replacement plug or do I have to go to a junk yard and find one?
I see some different types of GM plugs come with a short wiring harness with a plug on the other end as well. I don't know if my truck will use that or not.
Any help would be appreciated.
19 hours ago, davester said:
Maybe check that the other connector on the plug goes to ground?
I just checked the ground and there isn't any continuity from the ground wire to ground on the frame with the switch on.
I see that there is a ground wire coming out of the wire loom and attaches to the frame. That may be where it is loosing its connection.
I broke my back years ago and crawling under that truck just checking those two wires with popper clips makes my back real sore.
It will have to be a Saturday job for me to jack up the truck and clean that ground and see if that works.
I will work on it next weekend.
    DroppingDiesel
    DroppingDiesel
  • Who's Online   4 Members, 1 Anonymous, 994 Guests (See full list)
