Ok so here's my deal.  I have a 2007 gmc Sierra classic 1500 wt with 4.3. I have no power to transmission.  Reverse lights don't work, tow haul not working, trans. Temp not working, and won't shift by itself.  When i bought it they hooked it up to a code reader and it said tcm and fume canister.  I changed tcm and also checked every fuse twice. Nothing work.
You need to learn how auto diagnosis works.  For a given code your vehicle generates, the VAST majority of them are not of the type "replace part X".  The diagnosis procedure for a given code generally lists a number of things to check, and how to check them, to repair that code.
Seems like a snarky ass comment bud.  All i know is he showed me the code reader and it had two things.  Vaper can and tcm. Not sure how else i can describe it.
Do you have the codes?  Codes will help us help you.
Well, it can seem snarky, but it was just the truth put bluntly.
If you really want to diagnose and work on your vehicle yourself, I highly recommend:
-getting a subscription to the full-service manual from a site like alldatadiy.com (not that expensive), it has the diagnosis procedure for every code your truck can generate
-a knock-off tech ii .  This can read codes from every computer in your truck, as well as perform a wide variety of testing and repair procedures for your truck
38 minutes ago, Chris Rearigh said:
Hoping someone has dealt with this and can give me a place to start.
