Steering system overhaul
I am going to replace all of the consumables as far as steering goes. Inner and outer tie rods. Tie rod sleeves, pitman arm, idler arm, idler arm bracket, and steering stabilizer. All parts will be here tomorrow.
I’ve got a Hayes manual with all the torque specs. From the videos I’ve watched, everyone has removed the steering box to get the pitman arm nut off and then the puller on it to remove it. I assume I need to do that as well? I have a puller.
2000 k3500 4x4
Also going to do sway bar bushing. End links are already done.
Also, it doesn’t appear I need to remove the air dam. Hope not because that plow mount looks like a jerk to remove.
