Ya they will be paying more then just replacement
On top of the free detail
They ordered the wrong side first and couldnt return them so gave me both sides
Also there are a few what I would call stop spots where the ceramic is screwed up so they will be repairing that whenever I want to take it there....if it keeps bothering me I'll get it fixed only visible at certain angles up close
Sent from my Moto Z (2) using Tapatalk
  • 4 months later...
Still have to finish
Splash guards
Tailgate bar
Plow mount
Been quite some time since posting but finally got plow installed next month or so I'll be finishing up some other projects
714dfb83ad86411af2a6c8d7f71012b8.jpg7956d0e84eff64adcf6ed7eb283d855a.jpgf696ca22c213257eb4fed6da75cb5e27.jpgcdd6b7652ff8851d72663a1bde3e548b.jpg7483fb1a564a88827f9f7e76686a5312.jpgd4e853ec1b4fab8f5d79910ba02442ee.jpg5b19074ba87bad3fa44422ac55f0d31e.jpg6bbb784d6fcc24d31cd828891ec3ca64.jpg
Today's work
Front timbrens
cf7b9b0840f28fdc95454dd4a9dd5d61.jpgfc6876f4892fee24c8c5512fd8797b07.jpg6b6bf1019255e35ff6284dc618c27c85.jpg685f03effb20f6895707ab829cdc32ca.jpg42fe2167f1d9b0ec4a129e51ae17cdfe.jpg750dde2319f2312630bd04fda27fe49d.jpg7cb01f9adfb8480bff801e0fabd34168.jpg
Led reverse lights
Trimmed and Reinstalled lower valence
70739a19f3c38576a7a911bef656a5bc.jpgf0ca6d783eb0019f1f96a32d24dcb92c.jpg240f9fc739c6d16edd3150c6bfd03e2c.jpgf34fc0b79b11929e04a86203f928ad03.jpg
Ran wires thru grill
Tomorrow will install tailgate bar
And hopefully upfitter switch's that I've been putting off for months
Upfitter switches done
4c92e03bedd01930a258e3046d9dc85e.jpg5786f5976024f7e379c68a287a7780a5.jpg3871ec3040a604da25414cf1db3ae2ad.jpg
Tailgate bar all wired in
Reverse lights are super bright
What type/brand of light did you get for the back up light? Looks good.
Cheap ebay light used them a few times now and they are as bright as opt7 but a 3rd the cost and last 2 years (died in the winter few times)
They are directional turns so they go from center out best bang for the buck
https://www.ebay.com/itm/274426698996
Got my winter tires on....was cheaper to buy custom rims then used stockscb958401251998c6422f1671df444cb9.jpgccc23d36dabc37d580dd0537aa001b2b.jpg
Then had to work in a muddy area....they don't like mudd
Still have to get aux battery wired in...but after that I think I'm done
Well I may put in the bed heater this year but money is tight with the new toy accessories
So finally got my second battery installed and charging
It's just a quick install to try out this smart relay will finish cleaning up after I know it will work for me
0759f934572de30a0a1d26c27ad89094.jpg1a057458d3906f390c6907b9db564abc.jpgf108a816ea26da16a4203c1dec0db8e2.jpg
Bed heater installed should work as good as the last one
What’s the purpose of a bed heater? I assume it’s for things you can’t put in the cab that you don’t want freezing?
Fire fighting stuff.... keep it warm or dry it out....also helps melt the snow off the cover so it can operate
In my 1500 I had it set high and cover open to keep coolant temp down while out plowing
Not sure if that will need to do that for this truck
The 2 temp controls work together if ones not on the heater won't run
One kicks on when coolant temp gets to set point
Other kicks off when temp in bed gets to set point
Powered only when ignition on
How is this with the backup camera? Does it interfere or actually look significantly better/less grainy than just the IR
    250.6k
    liddlera
    liddlera
  • Who's Online   4 Members, 0 Anonymous, 463 Guests (See full list)
