Ya they will be paying more then just replacement
On top of the free detail
They ordered the wrong side first and couldnt return them so gave me both sides
Also there are a few what I would call stop spots where the ceramic is screwed up so they will be repairing that whenever I want to take it there....if it keeps bothering me I'll get it fixed only visible at certain angles up close
Sent from my Moto Z (2) using Tapatalk
  • 4 months later...
Still have to finish
Splash guards
Tailgate bar
Plow mount
Been quite some time since posting but finally got plow installed next month or so I'll be finishing up some other projects
714dfb83ad86411af2a6c8d7f71012b8.jpg7956d0e84eff64adcf6ed7eb283d855a.jpgf696ca22c213257eb4fed6da75cb5e27.jpgcdd6b7652ff8851d72663a1bde3e548b.jpg7483fb1a564a88827f9f7e76686a5312.jpgd4e853ec1b4fab8f5d79910ba02442ee.jpg5b19074ba87bad3fa44422ac55f0d31e.jpg6bbb784d6fcc24d31cd828891ec3ca64.jpg
Today's work
Front timbrens
cf7b9b0840f28fdc95454dd4a9dd5d61.jpgfc6876f4892fee24c8c5512fd8797b07.jpg6b6bf1019255e35ff6284dc618c27c85.jpg685f03effb20f6895707ab829cdc32ca.jpg42fe2167f1d9b0ec4a129e51ae17cdfe.jpg750dde2319f2312630bd04fda27fe49d.jpg7cb01f9adfb8480bff801e0fabd34168.jpg
Led reverse lights
Trimmed and Reinstalled lower valence
70739a19f3c38576a7a911bef656a5bc.jpgf0ca6d783eb0019f1f96a32d24dcb92c.jpg240f9fc739c6d16edd3150c6bfd03e2c.jpgf34fc0b79b11929e04a86203f928ad03.jpg
Ran wires thru grill
Tomorrow will install tailgate bar
And hopefully upfitter switch's that I've been putting off for months
Upfitter switches done
4c92e03bedd01930a258e3046d9dc85e.jpg5786f5976024f7e379c68a287a7780a5.jpg3871ec3040a604da25414cf1db3ae2ad.jpg
Tailgate bar all wired in
Reverse lights are super bright
What type/brand of light did you get for the back up light? Looks good.
Cheap ebay light used them a few times now and they are as bright as opt7 but a 3rd the cost and last 2 years (died in the winter few times)
They are directional turns so they go from center out best bang for the buck
https://www.ebay.com/itm/274426698996
Got my winter tires on....was cheaper to buy custom rims then used stockscb958401251998c6422f1671df444cb9.jpgccc23d36dabc37d580dd0537aa001b2b.jpg
Then had to work in a muddy area....they don't like mudd
Still have to get aux battery wired in...but after that I think I'm done
Well I may put in the bed heater this year but money is tight with the new toy accessories
So finally got my second battery installed and charging
It's just a quick install to try out this smart relay will finish cleaning up after I know it will work for me
0759f934572de30a0a1d26c27ad89094.jpg1a057458d3906f390c6907b9db564abc.jpgf108a816ea26da16a4203c1dec0db8e2.jpg
Bed heater installed should work as good as the last one
What’s the purpose of a bed heater? I assume it’s for things you can’t put in the cab that you don’t want freezing?
Fire fighting stuff.... keep it warm or dry it out....also helps melt the snow off the cover so it can operate
In my 1500 I had it set high and cover open to keep coolant temp down while out plowing
Not sure if that will need to do that for this truck
The 2 temp controls work together if ones not on the heater won't run
One kicks on when coolant temp gets to set point
Other kicks off when temp in bed gets to set point
Powered only when ignition on
How is this with the backup camera? Does it interfere or actually look significantly better/less grainy than just the IR
    • Pretty much zero rust on the truck, the frame is super clean. Non-snowy area of California for its whole life. They didn't mention JB weld specifically, just a silicone style seal.
    • Needs a manifold gauge hooked up and the pressures read.   If you don't have one, time to take it to a shop and have it diagnosed.
    • How rusty is the truck?     The transfer cases on these are an aluminum case.  If its anything like the rear diffs on the 2015-2022 Chevy Trax, those will corrode bad to the point it will push fluid through the housing via corrosion porosity or a crack from age/stress.    We have seen folks over tighten the drain and fill plugs on these transfer cases and crack them that way as well.    So I'd say its a 50/50 shot on re-sealing the case.  If all of the surfaces are good and its not badly corroded, they probably can re-seal it.  GM uses RTV to seal the case halves.   If they mention JB Weld, the issue is the case.  Be it a crack or corrosion.  JB Weld "might" hold if they clean EVERYTHING very well and drain the fluid out of the case and clean the crack and then seal it.
    • A while back, my truck (2018 GMC Sierra 1500 5.3) went in for an o2 sensor and routine service. The tech identified that my rear output seal on my transfer case was leaking, and recommended I have them replace it. At the time I didn't think anything of it, and had them do the repair. Less than a month later, I noticed that the recently repaired seal was leaking again. I called the shop that did the repair and they warrantied the repair and replaced the same seal again. A few months later, I noticed that once again the same seal leak had come back. It wasn't a great time to bring it in and I ended up just living with it for 6 months or so, noticing small (smaller than a baseball) size oil stains below the truck when it would sit for a while, as well as oil spray on the frame (to the point where it actually took the underbody coating off in that one spot). Finally got around to brining it in again, but this time I took it to a dealership service center since I am in a different part of the state for school. They identified the same output seal leaks and recommended they replace them. They also said there was no scoring on the inside of the transfer case, so it didn't need to be replaced. They chalked up the original repair failures to non oem seals and a job that wasn't done correctly. Now they called and said the seals are holding after driving/sitting for a while, but they found a very small leak in the middle, that they recommended they seal with some kind of silicone/jb weld (not sure what they are using). I haven't picked up the truck yet, but I have been reluctant about this whole repair process because I feel like they are just fixing the same thing that keeps coming back, and I am concerned there could be another root cause for the seal failing. Has anybody else experienced anything like this, or have any ideas on other things that could be the root cause?
