On 6/11/2020 at 8:20 PM, Supercup said:
Stayed with 18's and factory Duratrac's for now.  If I end up doing BDS lift - I will have to go to 20's - and at that time will add larger tires.  also note in these photos I have the RL half inch taller block in rear - in photo with stock wheels it was not in and the front was 0.25" high over back, now reversed.
RL 1/2" taller block?? I could only find a 2.25" block or a 3" block on the Ready Lift site?
Do you have the model number of the block you used?
It was part of the SST 2" level kit for AT4 - looks like on their website they are 3" blocks - when they went on we measured versus stock AT4 blocks and they were 1/2" taller.   So looks like they are the 3" on their site.
On 6/16/2020 at 5:28 AM, sweatandsteel said:
Nice! Here comes my order!
After alignment and new wheels/tires. 20x9 +1 offset Fuel Rebel on 305/55R20 Duratracs.
  • 3 months later...
On 6/16/2020 at 12:25 AM, Whiskey891 said:
How much did it raise the front end and how long did it take to install? Was it difficult?
Edited by LKGRenegade22
On 5/26/2020 at 6:21 PM, EXSlider400 said:
No. The spacer is less than 1/2” thick. It is not a 1:1 ratio. But I only used a bottom set and I was thinking about adding a 1/2” lift top set. Honestly I probably won’t though...not a high priority right now. These spacers are just a simple metal plate so don’t over think it. All spacers lift more than they are thick due to suspension geometry.
would you happen to have a link to this spacer?
