Advice needed on 7440 led bulbs,.....
Hi Ladies & Gentelman,     Can someone give me advice on 7440 Led Front signal bulbs (  no mods) built in resistor...… I don't want cheap  stuff and or 100.00  bulbs.....I bought some on amazon and were real nice but one defective today......paid 30 dollars Canadian...sometimes you get what you pay for!!!             It lasted 4-6 months.
 Thanks for reading                                   Goose Hunter
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
