Radio - Phone Pairing Issue
Hello All,
I can't find this in a search anywhere, but I hope I'm not the only one who's had this issue.
2020 Trail Boss LT.
Samsung Galaxy S8 phone.
Phone paired fine. I can see my contacts, etc.
Most (more than 50%) of the time it works just fine from the pushbutton on my steering wheel.
Push button "Yes"...Me: "Call Work" it calls...No problem.
But sometimes, particularly if I remote start but not always, I'll hit the button "Yes"...Me: "Call work"..."I can't find a phone. Please pair a phone...etc." But my phone is paired. I can see it right there. The screen says "Galaxy S8" shows my battery life, etc. It's paired.I've been to the dealership and they've done both the software and the hardware (replaced radio)...Still doing it.
On my end, the phone is completely updated. All installations recent.
Has anyone else had this? What am I missing?
Thanks for any insight on this.
  • 1 month later...
I have the exact same problem with my 2020 Sierra without using remote start.  I took a video of it doing this recently when attempting to place a call and it says “I can’t find a phone” and then I showed, on the same video, that the phone was connected.  And, I can make a call with my phone without pushing that button and it goes through the infotainment system (because it is connected).  I sent that video to the dealership the other day but I haven’t heard anything from them yet.  My 2018 Sierra didn’t have this problem.
I have the same problem.  Pixel 4.  It randomly connects to my phone.  I have the same issue when connecting a trailer.  Sometimes it shows the trailer is connected and other times it won't.
Thanks for the posts. I have the same exact issue as both the recent responses (still). Service department deemed it a hardware issue and replaced my head unit. But I'm still having the same issues. I really do like this truck but the tack in it was not ready for Primetime at all.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
