KBVoodoo universal crossbar review
I got the bars and was excited to install them. I was missing 3 locking nuts and the washers provided for the rail clips did not fit the bolts.
The holes in the crossbars themselves that you insert bolts into for length adjustment didn’t align well and it was a mission to get the bolts through. I emailed and was told “with a little finesse” they will go through. The bars are cool but not what I expected from a product this expensive.
Overall it’s a cool and useful product but after I ordered it I found a cheaper option, and given these issues, I can’t recommend it to anyone considering how much they cost.
Thanks for the review. Out of curiosity, what are these used for? I’m guessing kayaks and maybe bikes?
yup, I primarily got them to carry bikes when the bed is full of camping gear or whatever, but I might play around with a cargo rack and see what else I want to put on them, the cross sections remove easily for when you want to open the cover! I’ve been thinking of getting a kayak as well but not sure I can justify the cost on that yet haha
  • 3 weeks later...
I found those bars when I was searching for a possible bike rack. I have a Leer hard folding tonneau and love the idea that the bars are easily removed. What other product did you find? How are they mounted to the bed?
I got mine for bike racks and a cargo basket.
heres the cheaper option:
https://www.deezee.com/product/universal-hex-cross-rail/
in both cases the bracket hangs into the bed and clamps to the rail:
Does your tonneau have a rail that it sits on? My Leer has a rails that runs the entire length of the bed. I tested a 3/16th piece of aluminum that I had and it would fit under the rails (just need to add waterproofing afterwards) but I don’t see how the brackets attach to the bed side. Do you use the holes at the stake pocket?
I have the bakflip Mx, it does have rails that run the length, I added some weather stripping. they don’t use the stake pockets, the flat section of the bracket sits on top with a a piece than hangs into the bed, then it has clips to attach it to the inner rail similar to how the bedcover rails attach. I can take a better pic for you tomorrow if you like. This design allows you to place them anywhere on the bed that you like it’s hard to see in my picture but you can see the two nuts that secure the clips of the bracket to the inner rail, those are for the bars and not the cover
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
