Took the truck in for my free oil change and tire rotation (1st service visit) and was told of two recalls that I needed done - one transmission software update and one wiring harness. They had to order the parts for the harness, but performed the software update. I gotta say, maybe im just lying to myself, but the transmission shift noticeably smoother. Here is the information, if anyone needs it and needs to get theirs updated.
  • 3 weeks later...
Took mine in today for first oil change as well and had similar recalls today. One for the engine harness and one for a trip estimation something or rather? I dunno. I only saw the Brake controller as listed as a recall when searching my VIN so not sure why the other two didn’t get announced?
hopefully they have the parts in stock
What trucks do you guys have? Engine/tranny ? Year?
Sent from my Pixel 4 XL using Tapatalk
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
