So I pulled the trigger on a 2007 Classic Duramax LBZ
93k miles
Original owner
Amp steps
Lift
New shocks
Liner
New caliper and brakes
Sound
New gear box
52 gallon tank
Paid 23.5k
If it's 4wd, you might want to check with the P.O. if it has a pump-rub fix installed in the transfer case.  If not, you want to either install a fix (requires removing the transfer case to install it, weekend project), or regularly check if the hole as appeared in the transfer case.  Where the hole appears, it's above the fluid level, so it generally doesn't leave a spot under the truck, but rather the fluid exits only while the truck is in motion.  And when it's empty, the TC turns to mush.
Thanks. Any immediate recommendations on have to mods?
Yeah. Get rid of the lift or get bigger tires.  Otherwise great looking truck!!
    DroppingDiesel
    DroppingDiesel
  • Who's Online   4 Members, 0 Anonymous, 893 Guests (See full list)
