AC problem
Badboy4435
I have a 2003 GMC Sierra 2500 Duramax that keeps blowing out the Freon from the AC Compressor. I have replaced the compressor 3 times, fan clutch and condenser but it keeps building up too much pressure. What else could be causing problem?
About the only causes of that would be a severe overcharge of 134a, or blocked airflow across the condenser (or the wrong condenser - too small). Fan installed the correct direction?
Before I had a scale and good gauges, I used to charge by feeling the inlet and outlet of the evaporator. Once they're the same temperature, or, the outlet is slightly cooler, that's it for refrigerant - she's full.
You should have a high pressure cut-out switch that will shut the pump down before it blows off.
Have you put gauges to see what your pressures are?
All the work is being done by a reputable mechanic but I think he is perplexed on this problem. He has a 4 bay garage with several mechanics working there so i'm sure he has all the equipment for the job.
Maybe they got a batch of chinese 134a, which ISN'T 134a? Time for a sniff test ...
Then you need to find someone who knows more about AC or specializes in it. If your guy is perplexed move on.
Make sure he's charging by weight and not over charging. Not adding too much oil. Pulling a proper vacuum to boil off all moisture. As noted above counterfeit 134a is a possibility also. There are guys using all kinds of chemical combos out there
I’m a pretty good general mechanic. I’ve used the store low side fill with some good results. There’s so many stupid little things that can be wrong with an AC system. Once a simple low charge check doesn’t lead to good results. It’s best to find an experience AC technician. I almost changed a compressor and condenser. It turned out to be a o-ring. Lesson learned.
    mighty K20
    mighty K20
  • Who's Online   4 Members, 0 Anonymous, 644 Guests (See full list)
