don't know where it is in your truck, but in mine it's inside the cab near the driver's feet.  You might consider turning the key on, everything else off, then turn the blinker on and follow the clicking sound.  It's location may also be described in the owner's manual.
On the 2007-2013s, there is no clicker relay.  The sound comes from the driver's door radio speaker.  Probably controlled by the BCM or something like that.  If your flasher or turn signals are out, there's probably a bad bulb or ground someplace.
I replaced my turn/brake and DRL lights with leds that supposedly are can bus complaint, still getting hyper flash. Told to change turn signal relay for led type. But since with model doesn't have a relay what to do??
Anybody been through this?
NOW you tell us about the LEDs.  Common complaint on here.  One dude incurred a cost of $1-2K while his GM service dept chased electrical gremlins for days because he didn't tell them he'd put in LEDs.  When they found out, they handed him the bill and said it wasn't covered under warranty, and he'd have to pay to get his truck back.  There's a lot of supposedly compliant LED stuff available on Ebay and the interwebs.  A lot of GM vehicles don't like it.  Hell, the computers are so damned picky they don't even always recognize the OEM trailering equipment anymore.  Even changing spark plugs to a brand other than AC Delco or NGK doesn't seem to work out very well for some folks.  You'll either have to source a brand of LEDs that works on GMs (use the search function on here) and/or pay your dealer $$$ to make it work, or just bite the bullet and go back to the OEM type or good ol incandescent light bulbs that work every time, but are just not so bright.  Most of the OEM incandescent bulbs last 10+ years, with the exception of the models where the low-beam headlamps are also the DRLs.
Edited by MaverickZ71
Yeah I am learning the hard way...nothing new for me!
So I figure I'll try the load resistors. Do I need one of each bulb, front and back or just one for each side?
I was always told one on each side should suffice. I have a 2002 Sierra Denali and changing everything out this week. We'll see what happens!!
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
