Lifted trucks with stock wheels
I've got a 2018 Silverado Z71 and I want to lift it 4". I'm not a fan of after market wheels and a wide stance so I'm trying to find a setup that doesn't increase the track width and uses stock wheels. I'm looking at Fabtechs 4" lift because they claim it doesn't incease the stock track width. Does anyone have any experiece with this? I've seen a bunch of guys running 4 or 4.5 lifts from bds and zone but they both make the tires stick out. I looked at the stock wheels on lifted trucks forum but I'm having trouble finding anyone with a lift that doesn't increase the track width. Your help is appreciated!
https://fabtechmotorsports.com/product/4-basic-system-w-rear-stealth-shocks-k1116m/
CST 4.5" lift is what you want
TXGreek has this on his truck and he says it's the best 4.5" on the market. I would agree.
SSchup has the same lift.
It keeps the factory track width.
Hit up the Greek. He can help you out.
Sent from my Pixel 3 using Tapatalk
I second the CST 4.5”. I’m running it with stock midnight edition wheels and a 35” toyo open country R/t tire
Pics? Are you running any spacers on the front or back?
Appreciate it, I'll reach out to them
This is the only pic I have at the moment. I do have a spacer on the back which is not really necessary. The place I took it to figured I needed a spacer to match the front track width but with the CST it is not necessary.
Thanks, some pics down the side would be great when you have a chance. So, I looked at the CST lift and I noticed its not a knuckle lift, it uses brackets to drop everything down. Any down side to this? I thought knuckle lifts were the way to go when it comes to quality and long term life
When I get home I’ll get one for you. Everyone has their own opinion and will tell you their personal preference. This is the kit I went with and I haven’t had any issues. All my alignment specs are within range as well. Only down side to CST lift is I will need to repaint all of the CST parts. Salt in the winter sucks.
39 minutes ago, DominatorZ71 said:
Well the more you know. Unfortunately only 4" and can't use OEMs
Its the only knuckle kit that I've found that doesn't increase track width. Same thing for their 6" kit, no increase in track width, I'm just leaning towards the 4" kit right now. So that's the thing, all of these suspension companies say you can't use OEM wheels but if you check out the "Stock wheels on lifted trucks!" forum, you'll see tons of trucks with knuckle lifts and stock wheels. I'm just trying to find someone that specifically uses stock wheels with the Fabtech kit, haven't seen that exact combo yet. But there are tons of trucks running zone, bds, rancho, superlift, ect with stock wheels. Usually no spacers, in the front too. Which for me is the lure of the fabtech kit, if I could run it with no spacers up front I would be doing great
Link:
Link:
Those Fabtechs weren't on the market when I made a purchase. It was the CST or Rough Country. The knuckle lifts normally allow OEM use it's the bracket lifts that say you can't under 20". Mine even says cant use with factory 18s but I saw someone else do it so here I am. Rules are meant to be broken.
Fair enough. Anyone running the 4" fabtech knuckle lift?
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
