Can anyone suggest a good cell phone mount for my 2015 Silverado 2500?  With the texture on the dash pad, suction cups won’t hold and there really isn’t a flat space on the dash itself.  I prefer not to mount it to the windshield, NJ is funny about that.
Retrofit HMI 2.5 so you can have Android Auto / CarPlay.  Plug directly into USB, use head unit to control what you need.  No reason to have a mount in these trucks.
I have a 2016 with Android Auto and I use it religiously. I have a Proclip USA center console mount on the driver's side with a short USB C cable. Every time I get in I drop my phone in the mount and connect the cord. Everything is neat and in its place and at a fingers touch if I need something beyond what AA offers. So I agree that AA and CP are great but I don't think they negate the need for a mount.
Sent from my Pixel 3 XL using Tapatalk. My build thread: http://www.gm-trucks.com/forums/index.php?/topic/192614-Tenscourts'-2016-LTZ/Z71-CCSB-4WD-Silverado
That's what the rubber ridged thing in the center console is for.  I have a short USB-C cord  that plugs in, it sits in the rubber thing and doesn't move.  GM put it there for a reason so you wouldn't need a mount.
Edited by Nitrousbird
They also gave us a wireless charger that hardly fits any phone made in the last 4 years and no AA or CP wireless support. I realize what the ridges are for. If you read my build thread you'll see I made a custom mount with the USB C connector extending up through the ridges to basically dock my phone every time I got in but ultimately it wasn't stable enough. I found even placing my phone on its side to be cumbersome and to use the phone required disconnecting if you used a short cable which kills AA or CP. With the mount I get the best of both worlds. Easy access to the phone and AA. Again, I don't disagree about using AA and CP but the person asked for mount recommendations and I don't agree that using AA or CP eliminates the need for a mount not to mention the hundreds to thousand plus dollars it would cost them to get a new HMI programmed just to get to the point of having AA and CP as an option.
I have a scosche magnet mount thats attached via double sided tape next to the radio screen and it works well and i use the same mount for my tablet when i have gaia gps running
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 481 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
