Has anyone attempted to change 2500HD front clip to a 2016 Silverado 1500 front clip?  Curious to what all has to be done for this process to work.
There's threads already started about this I believe, hopefully no one goes at you for not searching lol.
Well on second thought maybe not reverse like you're asking? I would ask why you'd want to go reverse to a 1500 clip, cause usually everyone goes 2500, but to each their own.
Well I call myself searching for the swapping the 2500 front clip to a 1500 front end and couldn't find anything.  The reason why I would change is because the headlights are way more appealing than the HD ones.  Not to mention the light output is 10 times better that the factory HD lights.  The grill and bumper of the ltz 1500 is way more appealing that anything on the 2500HD
19 hours ago, newdude said:
Not unless you want to have cooling issues.
Just color match your HD front.
What would cause the cooling issues ?
I agree 100% to the light output, sorry if I came off rude in my first quote. In regards to that I have been window shopping headlights and found these Chevrolet Silverado HD (16-19): XB LED Headlights, I just can't justify to myself spending $1,400 on some damn headlights ?, if they were half the cost I'd probably get them for sure. They are pretty nice though.
The 1500 front has less opening for air flow than the HD.  If this is for your Duramax, the bumper swap will block off the trans cooler as well.  Don't think you want to overheat your Duramax, would you?
Edited by newdude
Your good bud... I also have been tossing around some different ideas also but cant really find something that I want to pull the trigger on.  I'm somewhat familiar with front end swaps as I did one on my 2003 Tahoe.  I installed the Silverado front clip on my tahoe to be different.
This is a picture of my 2500 now and this the front clip that I'm considering.  I really don't see much difference from one front end to the other in air flow blockage.
Your truck is bitchin man, personally I wouldn't mess with the 1500 clip. I'd do the 2017+ HD hood instead? I'd say color match to, but I don't think it'd match the rest of the truck look.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
