Anyone with a Sierra 3500 knows of a mod to add a permanent 4 pin plug on the truck.  I'm currently using a 7 pin to 4 pin adapter for my trailer and I keep losing it so I had to buy it 3 times already. I need a permanent solution so I don't need the adapter.
Just a thought, maybe convert the trailer to a 7 pin? I converted my boat trailer to a 7 pin so I didn’t have that problem. My old truck had both but 7 pin seems more common so that’s what I did to future proof.
I can't convert the trailer to a 7 pin because there are 2 other people that I share that trailer with and they don't have a 7 pin on their trucks.
Can't get that either because the 3500 have have trailer camera plug together with the 7pin plug. If I remove that to replace it with a 7pin + 4pin combo, I lose the trailer camera plug.
On my small utility trailer that I share with my brother I opened up the 7 pin connector and spliced in a short 4 pin pigtail. You need to keep the unused connector covered when the other one is plugged in...
As you can see from the picture he broke the 7 pin the last time he used the trailer and I will need to put a new one on.
Sent from my iPad using Tapatalk Pro
Simple solution. I'll definitely do that.  I prefer doing this rather than modifying the truck. Thanks.
Another option we use at work because everyone looses adapters. We wire in a separate female plug on the trailer with the 4 pin coming out of it as a male plug.  this way you have to have the 7 pin male plugged in and it is protected from the elements. Little extra work but somehow that is a system they haven't broke. Had some operator error when they forget to plug the other one in but that didn't surprise us??
  • 5 weeks later...
    d.lowrey
    d.lowrey
  • Who's Online   1 Member, 0 Anonymous, 2,944 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
