New to the forum so I have 2017 slt Sierra 5.3 that has headers intake and tune, motor blew at 76k miles swapped the motor for another 5.3 from a 2018 with 23k miles but get power reduced my mechanic can’t find the problem says all the wiring is reading the correct voltage and the ground is good has been sitting for 7months already and can’t seem to fin the problem can anyone help me out?
Reduced Engine Power should trip some sort of fault, then you can diag the problem from there.
I’m thinking I’ve been lied to on the year of the motor I did the swap with because I’m reading that 2014-16 use a slightly diffent ecu
Did they swap just the motor or the ECU as well?
The 2014-2016 uses a E92 computer and the 2017-2018 uses a E92A but that isn't going to matter here. The older computer shouldn't have been used in the first place.
There are other differences on some sensors from early to later years though. Like parts of the high pressure fuel system.
  • 3 weeks later...
Found the problem guys thanks for y’all input really appreciate it so the motor that I bought had dad a different fuel rail and fuel injector took my old ones from blown motor cleaned them out them on boom! No check engine and running smooth! After 7 long months lol ? I think the computer does read that fuel rail or some idk
    DLZ
    DLZ
  • Who's Online   5 Members, 0 Anonymous, 632 Guests (See full list)
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
