I have a 2016 Silverado LTZ that had factory wireless charging in it.  A month or so ago, my old android phone quit charging on the wireless center console, thought maybe my phone was going bad, didn't think much of it.  A while back I had ordered the newer wireless charger (the one with the three coils instead of just one) from GM and got it installed. My phone still will not charge.  One of my kids just got a new iPhone SE and it also will not charge.  What might be the issue here?  Is there a specific fuse that I should check? I didn't see a specific fuse mentioned for this in the owner's manual.  Anything else?
Thanks
49 minutes ago, bkesting said:
Anyone got any advice?
Swap out your console charging unit for the Gen 2 charger. The underside of the lid is held on with clips that pry off and expose the charger. The Gen 1 charger had issues apparently, maybe yours went completely bad. Here's a new one listed on eBay: https://www.ebay.com/itm/2017-2018-Cadillac-Wireless-Charger-Charging-Retrofit-iPhone-X-Android/283110063260
Well. I installed the updated wireless charger and my iPhone 11 Pro was charging until a few months ago. It’s hit or miss if it wants to charge. It recognizes that there is a charger there but won’t charge. I’d say it works about 10% of the time. My wife’s new iPhone pro does the same thing. The funny thing my sons IPhone XS charges just fine every time. I’m wondering if it’s something with a software update and the pros hardware. As for iPhones this has been discussed on previous threads. No solid conclusion.
I have put in the Gen 2 charger.  My old android won't charge and my son has a new iPhone SE and it also does not charge.
Yikes, looks like GM missed the mark with the Gen 2 chargers as well. Never mind about the OEM option then. I know there's a thread on here about guys installing their own chargers underneath the lid. Do some searching and maybe go that route.
I installed the gen 2 in my 2017 Suburban and it only works when it wants to. I cut up my 2014 Sierra console lid and installed my own and it still works.
My original Gen1 charger had quit working, so I put in the Gen2 hoping it would resolve the issue.  Must be something else at play.
The wire that feeds the wireless charger is in a bad spot, runs next to the lid hinge.  My hinge chewed through it.  Also, the newer phones are incompatible with that old wireless charger, there is a guy that sells the newer units and adapter since the power connector is bad.  My opinion, dont screw with it, use the cord to charge.  I did the upgrade and the charging is VERY slow..  Not worth it.
If I leave my phone on there for more than 5 min it starts charging. I mostly use the cable because I use waze when I travel
So I updated to IOS 14 and have no problems wirelessly charging. Every time I drop it on the mat it charges.
Not sure if you solved this, but I did a mod and added an aftermarket charger. Here's my thread on how to do it, with pics:
    DM22
    DM22
  • Who's Online   5 Members, 1 Anonymous, 1,220 Guests (See full list)
