Just finished off my jump seat to console swap On my 2020 LT Trail Boss...It took me 45 min start to finish super easy swap out...All the plugs and oulets work except for the ones inside the console itself...Does anyone know how to get power to the USB outlet inside the console????The light inside the console works...Is there another harness i need to power the USB inside the console?
Edited by Booma1218
There is a harness that runs from the rear of the dash usb to usb inside the console. I'm not sure if the current dash usb needs to be replaced or if the harness just plugs directly into the existing one. There was a topic on this if I remember correctly.
That harness had been cut on mine when I did the console swap. So I just ordered the blank filler plate.
Thanks..I’ll look into it
I've been wanting to do the same thing for my truck. Do you happen to have a list of the part numbers you needed and did you order straight from the dealership?
I got it from car-part.com..It's out of a 2020 LTZ literally the thing was brand new when I received it...It came with every single piece needed including the harness for 550$ plus 65 shipping ....It tool me 45 min to complete the whole install...Going to the dealer and buying all the pieces and what not would be over a 1000$ i'm assuming...They have a couple more on car-part for the same price i paid...I highly recommend using them and saving yourself some cash...
Just a little curious when you did the search what did you select under the part? Console front? gonna try and keep an eye out on there for one for my truck
For whatever reason the link isn't working...Yes,after to select year,make,and model, go to interior and select front console...It will list what's available...I just looked and there's a few for sale on there now
I just did the exact same swap on mine as well. Love it, and worth it. For the Center console USB/SD car block, you will need the extension wire harness (part number 84376073) goes from the back of the USB block (there will be an open port) on the dash under the buttons to the main harness plug which should be located beneath the cupholders. This extension will power/connect the USB block inside the center console to the truck.
Now, with that said, the issue I am having is that the infotainment screen gets stuck on the Chevy bowtie logo with everything plugged in/connected. I have narrowed the issue down to just the USB block in the console. When is has power, the truck doesn't like it. I am trying to find a fix for this... assuming it's a programming issue of some king. Some way to tell the truck that the SD/USB block is installed.... thoughts??
On 1/13/2022 at 8:49 PM, Beaujames83 said:
2021 LTZ with full tech package. Want to swap out my center console to folding leather seat with storage. Anyone wanna trade parts for parts. Each pay own shipping. Mine has wireless charging and every thing else.
Did you by chance figure out the usb block issue in your console?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,140 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
