I have a black leather jump seat with the locking storage underneath. Seat has never been sat in, leather in great condition. Anyone interested in buying? I just swapped in the full center console don’t need it in my garage.
On 4/7/2022 at 1:38 PM, denny noname said:
I'm looking for a center console, will it work for a 2020? I think it will, but not 100% sure. I have black center seat cloth, no storage, doubt you want with no storage. But willing to buy.
Won’t work. The trim on the top part of the console isn’t flat like the Silverado/Sierra. It curves up. I have this swapped in my truck and am looking to see if the top where the wireless charger is can be changed to the Silverado one. Last pic is a cutout of something that could be made, but I’m also planning  add-on of second screen for radio
  • 10 months later...
5 hours ago, Joeslime619 said:
I have a 2023 gmc elevation w/ front jump seat. I want to swap it with a 2019-2021-2022 center console. Will this fit and line up with the dash correctly?
_Yes the console will fit and line up perfectly. You will need the lower trim piece that goes between the lower dash and the front of the console. Search the forum for center console swap to find the part number.
I have a 2024 Chevy Silverado 1500 with a leather jump seat that I’m trying to swap to a full center console. Can someone please tell me if I’m even able to because I’ve seen so many videos that show me yes but my dealership says no such thing I would have to trade to a truck that offers that.
  • 8 months later...
Hey everyone!
I managed to get a console to swap my jump seat for my 2025 Silverado trail boss custom.
Everything fits as it should although I’m running into an issue where the wiring harness connection seems to have changed.
has anyone run into this or have a resolution for it?
1 hour ago, Atourlas said:
Hey everyone!
Welcome to the forum. What year truck did the console come out of?
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 162 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
