5 hours ago, Bigfoot16 said:
after..
Looks awesome. Nice truck!! My favorite wheel GM has produced.  I would have put them on but these Midwest winters kill the chrome around here.
2 hours ago, mafd2 said:
Nice! Chrome looks great ?. Better than the black ass rattle can looking wheels ?
Thanks.. I had a feeling you might  say that :)
Thanks.. :)
