Any idea the best way of doing this? i used a pac previously in my 2008 gmc. i dont see that they make one yet. My amp is capable of using the speaker input as a remote turn on but i dont want to splice into the factory speaker wire.
LLJ Customs makes a t-harness that will connect right into your factory plugs behind the glove box.
Lmk how your gonna get around the amplified chimes, turn signal and front and backup sensors if you got them.
I know you said you don’t want to splice...
however, if you pop up the plastic on your front  door sill on the passenger side (in the harness) you’ll find a twisted pair of blueblack and white. Those feed the rear door speaker on the right door.
on the driver’s side they’re Green and greenblack (if I remember correctly). They feed the left rear. They’re easy to tap into for a line out converter.
that’s what I did. It worked out great.
  • 3 weeks later...
  • 1 month later...
My current Acadia has the factory Bose system with 10 speakers, great for OEM, but not as good as custom :thumb:I hated the 6 speaker base system in both my previous Acadias.You can not replace 8 ohm speakers with 4 ohm speakers. Short time frame, okay... but you will burn out the amplifier shortly. I was told about this by a friend who is engaged in event staging services and often meets with problems in his car with audio systems and in his work.The amplifier is not designed to run at 4 ohm and will have problems delivering enough power to those speakers. Eventually you will fry the amplifier.
Edited by OliverThomas
OK, so I just purchased a 2020 GMC Sierra SLT with the Bose Premium Sound system.  At this point, this is where I am.
Considering these speakers and enclosure: > https://www.jlaudio.com/collections/car-audio-stealthbox/products/sb-gm-slvcc4-12tw3-d8-car-audio-stealthbox-94668
* A little pricey, but hey JL Audio quality
With this AMP: > https://www.jlaudio.com/products/xd400-4v2-car-audio-xdv2-amplifiers-98602
I need the schematic for the Bose Premium Sound system, what model Bose, information (all I can get), to include if possible the stock amp.  Does this Head have a low signal output (for subs)???
Something else I found which was really interesting is (not to use the rear speakers for signal input)
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 1,413 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
