ill try to summarize this as best i can to make this an easy read. Started out having to replace upper control arms, lower ball joints, and new tires one week ago. Which lead me to getting an alignment. while my truck was on the lift it died and the guys at the shop had to jump it off. well the week following my battery was defiantly showing signs of weakness. On Monday 8/17, was headed out the door and tried to use my Chevy app to start my truck, kept loading and loading and then said i needed to reconnect  my truck to the app. same thing with Onstar they were not able to unlock the truck. finally was able to break in. Next day my truck wouldn't even start,  had to get it jumped off. As the week went on the truck was still having a hard time cranking. So i went and replaced the battery with the "best battery advanced auto had" which was a DieHard Platinum AGM Battery, Group Size H7, 850 CCA. As soon as i replaced the battery my back up camera kept giving me a (Service rear Vision System). I've checked the fuses and they all seam to be fine. Now here's the kicker. Granted my truck does have 133,000 miles on it because i drive from Dalton to Atlanta for work. Wednesday night im driving home, and my truck begins to slightly jump like its misfiring a cylinder. Its not real bad but just enough to know that somethings up. Next morning drive to work, and still kinda feeling weird and then it begins to make a hissy noise when i accelerate. i can definitely tell you it has never made that noise before. To beat it all, Yesterday 8/21, im driving home from work, and my truck started making this awful sound under the cab around the transmission, and jumping real bad like the transmission is slipping. get down, the interstate about 15 miles and then the RPMs start going wacko. Im at about 40-50 MPH and in between 3000-4500 RPM and i know that is not ok. finally make it home and took it to a family friend who has a shop, runs a scan on it and code pops up for torque converter in the transmission along with 16 other codes. Now I can tell you, i had ZERO issues with this truck until i put a new battery in it and now trucks at home and im having to drive another vehicle. Someone enlighten me on whats going on because this is above my head. See attached images and video.
Thanks
IMG_4597.MOV
Edited by Ddouhne
The transmission issue sounds maybe like your torque is going out. The rear vision system is most likely a fuse. I had the same thing and that’s what it was. I’d check all the fuses inside the cab again.
I’m also wondering if running your battery dead to where it needed jumped a couple times didn’t mess with the computer some?
Thats what im thinking too. Cause all this started as soon as i put a new battery in. I'm getting it taken to the shop next week for a more in debth look on the transmission and run it through another scanner.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
