My 2018 GMC Sierra had check engine light flash several times but I went away and haven’t had it do it again, I didn’t notice a difference while driving and the light flashing. Anyone else have had this happen?
Also it just hit 30xxx miles the day it flashed
Flashing normally means possible catalyst damage, aka a misfire is the normal culprit.
You could try to scan the engine computer to see if there is a history code of the problem. That is all we could tell you at this point.
34 minutes ago, Pablo Villagomez said:
The truck is still fairly new, would the warranty cover?
When did you buy/when was it put into service? Sounds like you are good on miles as far as the 36/36000 warranty.
I bought it brand new, I had a lift and bigger tires added to it. I hear that the the warranty can be voided since it wasn’t done by the dealership.
Still would try, nothing to lose, especially if this can not be traced back to the lift.
Edited by JimCost2014
1 minute ago, JimCost2014 said:
Still would try, nothing to loose, especially if this can not be traced back to the lift.
Wouldn’t think this could be traced back to the lift, but I wouldn’t know. Do you think it could be?
To be very honest, I have no idea. Had a flashing CEL in my 16 when it broke a push rod, so not a lot of experience with this problem.
I would take it in, and have them run a scanner for codes, there could multiple reasons why it happened, and they may find nothing since it sounds like it is running good again.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
