I am looking for a lift that actually increases wheel travel.  The lift amount I'm looking for is 2"-4".   I don't want a spacer or block as it does nothing to increase suspension performance.  Has anyone added coil springs that are longer to the front of their truck?  Did you have to get different upper control arms and/or shocks for the lift?  I know that there are long travel kits out there but I'm looking for some mods that increase performance with a small amount of lift.
Thanks in advance for any help.
Bilstein 5100 will raise front 2” and gives you an extra 1” of front end travel. No need to change any components, uses stock spring, control arms etc.
Take a look at fox and king for larger lifts.
Bilstein 6112 is a larger diameter shock with new coil spring.
https://www.shocksurplus.com/pages/bilstein-6112-vs-fox-2-0-performance-coilovers-the-need-to-know
Uniball upper arms and some king/fox coilovers can give you 2-3 inches of lift and 1-2.5 more inches of travel depending on arms and coilover specs. I'm beyond satisfied with dirtking boxed UCA's and king 2.5's all the way around on my truck. Handles great off road, eats bumps and whoops very well on small 33's ead22307b7633e05ba0a20a4bd8659bc.jpg
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
