Hello Everyone,
Noticed that Melling offers items such as LS7 lifters & timing chains for a fraction of  what GM charges.
Any opinions on the quality of any of these items?  Have always had respect for Melling, but not sure what to think about this.  Thanks for your help.
fwiw  Melling if a GM supplier of the AFM lifters...
Seems like there's been an issue with lifter quality control & supply, for some time.  Am willing to pay a couple of dollars more for something  that won't fail prematurely, if necessary.
Have had my 5.3 open twice to service a bad AFM lifter.  Same thing.  The roller goes, but the cam remains pristine.  Wonder why?
Well, maybe I finally figured it out.  In my opinion, the weak point in this whole system is the lifter trays; and, I believe the AFM lifters are harder on the trays than their neighbors in the adjacent cylinders.
Amazing how tight the standard roller lifters still fit into the tray, and how loose the AFM lifters seem to be.  Not enough to spin, necessarily.  Just loose enough to cause damage, perhaps.
Anyways, first time in, I neglected to replace the trays.  This time, a full DOD delete + new trays.  Hoping for better results.  Thanks for helping me think it through.
Edited by GhostWriter
These may be helpful.
https://www.melling.com/wp-content/uploads/2018/03/Melling-tech-bulletin-on-GM-LS-Deactivation-Lifter-Issues-3.1.18-1.pdf
https://www.melling.com/wp-content/uploads/2017/03/why-replace-screens.pdf
Edited by Grumpy Bear
Replacing the trays is SOP anytime you're in there, good insurance.  Melling is now and has been in the past the OE supplier for many engine parts including water and oil pumps, camshafts, lifters, etc.
6 hours ago, Grumpy Bear said:
Thanks.  Received my Melling oil pump & pickup tube/screen assembly, today.  Trying to leave no stone unturned, this time.  Thanks, again.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
